vroom ZOOM
- Aug 15, 2017
- 473
Hi there, I have a problem that has me STUMPED. When I push the button to turn the nav lights on, the warning horn comes on and I can hear the high pressure fuel pump on the engine kick in! Say WHAT???? Yes, this is with the key out of the ignition. So I pulled the dash and all the wiring thinking that the engine on power wire got shorted to the blue instrument cluster wire - nope. So next I unplugged the blue wire from each gauge - problem goes away. Just by luck when putting it back together I noticed that the problem occurs when I put the bulb in the trim gauge! On my outboard, the gray wire is the wire that gets energized when the key is on. The gray wire also goes to the dash to power up the instruments. So well I grabbed a test light, unplugged all the wires from the trim gauge except for the blue one, put the bulb in, and turned the nav lights on. Testing between ground and the power terminal on the gauge where the gray wire would connect, the test light turns on! so it seems like it is shorting through the bulb, ground, gauge and into the power supply??? what the heck? Is this normal? With the nav lights on the trim gauge works normally! How do I fix this?
