skyler4321
- Dec 11, 2010
- 14
Just got a 2003 Maxum 1900SR 19? with 4.3L Mercruiser.
In the pictures the shop floor is nearly level, the tongue jack is all the way up, with the drive full in and there is still more than an inch under the drive.
It is almost 5 feet from the nose of the boat to the tip ball coupler.
It does pull very well down the highway. I have not tried to launch it. I do not remember my other boats sitting so high on the rear of the trailer.
The trouble I have with this setup is that I can not back it straight into the garage. My Bryant 192 (19? 4.3L Mercruiser) fit fine. Second with the jack up all the way the bilge will not drain.
The good news is that the trailer is fully adjustable.
Currently it is 18 feet from the center of the axle to the center of the coupler where the ball goes. This makes a 19' boat take almost 25'.
Here is what I am thinking.
1. Move the rear of the bunks down, maybe two inches. This should also move the bow up.
2. Move the winch all the way forward, about 9?. And up to the new bow position.
This should move the boat forward about 12?
3. Move the bunks forward until they are flush with the transom, about 12"
4. Move the axel forward to adjust tongue weight.
Not sure if all of this is a good idea. Is it okay to have sloped bunks? How far above the ground should the transom be? Is this boat currently being properly supported? Or anything else you see that may be wrong with this set up.
Thanks for the help
Thanks for the help
