Should I paint this??
chrisf695
I just picked up a much nicer condition alpha transom assembly and while taking off the main oring seal, I took off some paint on the edge of the inner part from an adhesive remover... the guy used 4200 under the seal and it wasn't coming off easily, so I ended up using a plastic scraper and some remover called "Goof Off" from home depot.
Should I kinda sand it down and just shoot is will some black merc paint or just leave it?
Re: Should I paint this??
I would paint it with a self etching primer and then paint. However that is me.
gm280
Clean up that area and like Scott suggested, prime it with a etching primer and then even use a small paint brush or spray paint and paint over the chipped area and happen boating...
