Show your sub installs, Tahoe owners
TahoeQ4Pilot
Looking for ideas and tips on sub woofer installs in Tahoe SS or S&F models. Show your stuff.
dhendersonm
Re: Show your sub installs, Tahoe owners
2005 Q6 SF, 190 IO.
Sony 10" sub. MTX Marine amp mounted by accessory battery in engine compartment. Used dremel to cut out the hole for the sub. Took about an hour tops.
TahoeQ4Pilot
2005 Q6 SF, 190 IO.
That is sweet. I was thinking about putting speakers in that area, but I like your setup. I see you have speakers in the bow?
Looks good.
dhendersonm
I'll take a few more pics of the speakers in the bow when I get home from work. They are Dual Marine 6 1/2's. I'm going to replace them with Sony Marine 6 1/2's.
MelodyBay
2005 Q6 SF, 190 IO.
Very nice setup and clean install! Something that I have been trying to get around to do one of these days but I'm a little worried about making the wrong cuts.
Sound quality must be a huge difference over the factory installed speakers which I found hard to hear from the bow unless I had the volume turned way up!
dhendersonm
Using the Dremel attachement with the fiberglass cutter bit made it a lot easier than I thought. The sub came with a template and I traced it out with a sharpie being careful to keep the template on the flattest surface area. I then used a drill bit to drill 4 pilot holes at the 12, 3, 6 and 9 o'clock position on the circle. Starting at the 12 o'clock position I started the cut with the Dremel. It cuts so precise and with just a little pressure cut around the circle like butter. Go to three, then 6 then 9 and back to 12 and the hole is cut. Then I used my drill for the 9 screw holes for the sub. Test fit the sub and it was a little tight so I used the round sandpaper bit to smooth out the edges of the circle I cut out and test fit the sub again. Now it's perfect. Screwed it down and put the screw plugs over the screw holes. Done! Trust me I was nervous about this too until I saw how easy the dremel cut through the fiberglass. Hope this helps you overcome your fear of "making the wrong cut".
MelodyBay
Definitely not as hard as I thought. I do have a Dremel and never thought of using it for this. Thanks for the play-by-play!
dhendersonm
Using the Dremel attachment on the Dremel did three things for me.
Clean, concise and precision cutting. I might add that it would have been nice to have a second person running the wet/dry vac while cutting to catch all the fiberglass dust. I itched on my arms and hands for a day or so after as well.
splicer
I've heard of rubbing talc powder on your arms to clog your pores before doing fiberglass work. Then take a cold shower to keep the pores closed while you wash the fiberglass dust off.
