Shower Head
KRS
Banned
I have a shower head that articulates, it has a ball joint that is sealed by a rubber gasket (3/8" thick) that is concave to match the ball joint's shape. This joint leaks a little, so I tighten it and the joint won't articulate.<br /><br />Question is.... what to lube this with? <br /><br />Petroleum Jelly- or will that break down the rubber?<br /><br />What can I use?<br /><br />Thanks!
Ron G
Re: Shower Head
you can petroleom jelly,they make faucet grease you can get it at any plumbing store,are tou sure its nots lealing out of the spicket coming out of the wall,always use teflon tape on those treads.
Bob_VT
Re: Shower Head
There is a food grade grease (will not hurt seals or rubber) used on ice cream and milk shake machines. Go and ask your local McDonalds manager for some in a ketchup cup.<br /><br />Bob
KRS
Banned
Re: Shower Head
The shower head attaches to the standard 45 degree shower nipple pipe (chrome) from the wall, no leakage. Yes on the teflon tape, always a good idea. It's where the ball joint compresses against the rubber that it's leaking.<br /><br />Me: "Yes (16 year old McDonalds' manager) I'd like a cup of grease!"<br /><br />Manager: "Large order of fries, coming up!"<br /><br /> :D
dolluper
Re: Shower Head
Where did you say you were installing that on your car?????? :D :D
Baldguy
Re: Shower Head
Petroleum jelly will break down the rubber...better use the Mcd's lube.
Re: Shower Head
Spray Silicone,....??......
crazy charlie
Re: Shower Head
Moen faucets use a silicone lube that looks like a thin type of vaseline.I would stick to that.Charlie
Boomyal
Re: Shower Head
Originally posted by crazy charlie:<br /> Moen faucets use a silicone lube that looks like a thin type of vaseline.I would stick to that.Charlie
Ditto to CC, or visit a pool shop and get a tube of teflon/silicone pool filter oring lubricant. It's always good to have around the house and will work well for what you are doing. Vasiline will do the job until it breaks down the seal.
Ron G
Re: Shower Head
you cant replace the washer inside<if its the washer should pop rihgt out,or there may be a crack in it.
ae708
Re: Shower Head
Petrolium jelly is not good for rubber. I would use a silicone based lube (Sil-glide comes to mind) or Lubriplate.
