Simple Method Of Shift Shaft Setup For Mercury Outboards Verified
Status
Not open for further replies.
merc850
This is how I do it in about 60 sec.: Turn the LU shift shaft by hand counter-clockwise until it
stops, then with Vise Grips tight on the bottom of the shaft turn it a
few more degrees CCW until it clicks into a stop, this
should be neutral - check by turning propshaft --
prop should spin freely.
Put control in N and go ahead and attach LU to driveshaft housing some turning of the flywheel will help the DS splines align.
Do not shift into reverse unless you turn the prop at the same time.
Texasmark
Well said!
Maclin
Just went thru that on my 1979 Mariner 90. Had to move the lever slightly to Forward while "pushing" up on the lower to get the coupling splines from the upper coupling to align. I like this method better than "the book" version of leaving lever in Forward now :)
c webster
I had been running the motor with the throttle only button depressed help will be greatly appreciated this motor has less than 10 hours been in the barn for last two years
Status
