Went out to the lake this weekend and boat wouldn't start. Had is started in the driveway the week before. Troubleshooting and reading through the forums tells me I have a connectivity issues, battery, starter or solenoid problem.
Symptoms: Boat turns over with single crank each time. Sometimes it grinds after the single crank sometimes it spins. I have checked and tightened and cleaned all the connections. Today was able to start it but once again only on a single crank. If it catches great but I can still tell there some type of power starter issue. What is the best way to tell where I am failing. Can I test the connections with multi-meter or something?
Any other ideas what could be happening? Thanks David
