slow cranking
cpt hook 52
i have a baliner boat with 89,force 85 hp'was doing good,let it set for about a month then went to lake wouldnt start slow cranking,tryed to jump no chang.got back home bought new battery more cranking amps still no good,rebilt starter no chang,,,help
pnwboat
Re: slow cranking
Bad battery cable(s), or corrosion on the battery connectors. Very common. Most jumper cables are not heavy enough to carry enough current to the starter. This fools a lot of folks.
Disconnect each of the battery cable connections, both positive and negative, inspect the underside for corrosion and clean thoroughly with a wire brush or similar method until connector is bright and clean. Don't forget the negative cable where it is bolted to the block. I have to do this at the beginning of every boating season.
jerryjerry05
Re: slow cranking
After all that pnwboat suggests do a compression test.
Check the lower unit for water.The bearings can rust and sieze.
Jiggz
Re: slow cranking
After cleaning cables and problem persists, try jumping the starter solenoid (large terminals) just to see if the solenoid is the problem. If problem persists do Jerry's suggestions first before continuing on.
