chrisandersen
- Nov 2, 2002
- 21
I have a 16' fiberglass centerconsole that i s supposed to be self bailing. The tunnel has two 1/2" brass plugs. The deck has two scupper valves. It sits on the water. The weight of the motor (75 hp) causes the scupppers to be underwater. So, water leaks into the deck when I get in. Then it pours into the the tunnel when the water in stern exceeds about 4".<br />How can I keep the water out of the tunnel so that the scuppers stay out of the water.<br />What are the best scuppers made that will keep water out?<br />Is there a way to get a bilge down there? I may be able to stick a tube in there, but that's it.<br />Thanks
