Small Johnyrudes. Number of cylinders?
StuartT
I'm confused. Copies of Evinrude and Johnson brochures I have found online noticably omit the number of cylinders on the small engines. Here is an example from 1997: http://rides.webshots.com/album/559448760OAsjGC
So maybe someone can give me an education here. In the 80's and 90's, it appears there was a 2hp and a 3.3hp which I assume were single cylinder units. Then there was a 3hp and a 4hp, where the 3 was the same motor except extra long shaft (25"). Then, of course, there were the 6's and 8's which were definitely twin cylinder outboards.
Question: Were the 4hp models singles or twins? And where did "Deluxe" fit into all this?
Rick.
Re: Small Johnyrudes. Number of cylinders?
The 4 is a 2 cylinder. Great question about the deluxe model. I have no idea, maybe it has gold lettering. Rick.
Vic.S
In the mid 1980s at least the 4hp models were 2cyl 87 cm? engines. The standard one had a leg similar to the 2hp with 360? swivel for steering and just forward and neutral gears while the Deluxe version had a leg similar to the 5 hp and was equipped with a a FNR gearbox. They were both available with integral tanks or remote tanks, although the integral tank fitted to the deluxe version was larger. at 2 litres instead of 1.4 litres
The deluxe version was approx 7.5 kg heavier. It also had a "shallow water" drive facility.
The deluxe version had a cover similar to the 5hp and larger units.
1984/5 brochure in front of me! (UK version) No gold lettering mentioned in the spec!
StuartT
Thanks guys. Glad there is such a reliable place to go for answers. And the explaination of the Deluxe version will undoubtedly be useful to a lot of us on this site.
tashasdaddy
the 3hp is a 2 cylinder, while smaller are one cylinder.
Rick.
That is interesting information regarding the deluxe model. I was joking about the gold lettering. I have a 1971 4HP, Evinrude. It has no neutral or reverse, just forward. If it's running, it's moving. A shifter with gears would have been a nice feature for sure. Haven't run across any with an integral tank but will keep my eyes peeled for that. Rick.
1946Zephyr
The smallest of twins even came in the early Johnson 2hp's. They were cute little motors and were a smaller match to the old 5hp's.
