Snapped seat bolt
nola mike
The front seat in my '97 ranger (which I swiped from an explorer 16 years ago) are worn enough now that the springs have cut through the foam. Back to the junkyard and got another "new" one. One of the bolts (out of 4) holding the frame to the floor snapped off. Against my better judgement used an EZ out... And you know what happened. I now have a broken EZ out in there. Any suggestions? there's a heat shield or something beneath them, but the rear bolts just look like they're just tapped into the floor pan. Thinking of drilling through the top side of the rail and pan and either tapping or through bolting the last mount.
dingbat
How thick is the floor pan?
I've had great success using "gripserts" in a variety of sheet metal applications?
This is on your rusty but trusty truck?
there should be a weld nut attached to the sheet metal. I would probably put in a few self-tapping sheet metal screws, or get the carpeting a bit wet and weld the bracket to the remainder of the broken bolt / ez-out
nola mike
Not sure. That's what would keep me from just running a tap through it. I don't think the gripsert would work, it would need to keep from tearing the sheet metal in a crash.
Yeah, check out the seat. Pretty sweet, right? It's heated but someone swiped the switch. The wiring was different, and to get the heat to work I'd need to run a switched power source. It's taking every ounce of me to not do that. I did spend way too much time getting the power lumbar to work correctly. Also had to do some mods since this was a passenger seat. Just drove down in it. It is SOOO much better than the old seat. Also replaced the headlight switch (it was needlenose pliers activated before) and the cruise control switches. Believe it or not, the only thing not functioning ATM is HVAC (heat has only worked on max since I got it, A/C went out last year). We'll see how much motivation I have to fix them.
There may be something on the back side, I can't tell. Once it gets dry enough for me to crawl under I'll see what the rear 2 bolts look like. Future me would absolutely hate today me if I welded that seat in there. Today me would also hate today me if I decided to try and weld around carpet on the front side and fuel tank/lines on the back side.
I still like the idea of going through the top of the rail. I can either drill a pilot hole to see how thick the metal is or cut out a bit of the heat shield at the bottom.
Other idea i had would be to cut out a 1/2" hole or bigger encompassing the ez out, and then cut a rectangular piece of plate/stock with a threaded hole in the middle and put it on the backside of the hole if that makes sense. Kind of like the trick you'd use to patch in some drywall.
nola mike
you know Ford is advertizing employee pricing right now.....
I've got 235k on the clock and beat the everloving crap out of this thing. The seat was $35, switches were $20. New plugs and wires last year were $50. Free oil change won at a flying squirrels game. Antique tags, no inspection or license fees. New drums and shoes 2 years ago, $50-100. Total cost of repairs/maint x 2 years = <$200. And it's a stick. Yeah, no thanks to the new crap.
briangcc
Ok hear me out on this...
On my Trans Am, the rear seat area had to be patched - T-tops and under the rear seat acted like a bucket so to say it rusted is an understatement. Anywho...idiot body shop #1 replaced the pan but didn't reinstall the nut that the seat belt attaches to.
I got some thick sheet stock and had a large nut welded to it. To attach it to my floor pan, I drilled a couple holes for a rivet. Riveted plate to the floor pan. Now I had a very solid mounting point for the seat belt - more solid than GM ever supplied.
May be an option for ya once you get the stuck bolt out...
