SNOW Common Sense
jimmbo
This was one nights' snowfall in April of 85. Motor was running when I took the pic. Drove it out of there about 20 minutes later. One Wheel Drive, with 1980's Winter Tires on the rear
jlh3rd
lol....yeah, then get sued by someone like in post #38.
Lou C
View attachment 414809View attachment 414808
Was that a '76 Olds? We had the same car, one year older, same color!
Except that ours had round headlamps instead of the rectangles. Great car loved it. 5.7 Olds & Quadrajet carb and Turbo 375 (IIRC) auto trans.
We got around in snow with Firestone Town & Country studded snow tires on the rear and 4-6 sandbags in the trunk.
jimmbo
It was a 76 Olds 88 Royale, It had the 455 with a Turbo Hydramatic 400. 2.56 Rearend.
I had the 4dr Hardtop, the old Man had the 4dr Sedan
Bob_VT
I have owned a snowblower since the 1978 blizzard...never have I had a clog that would not unclog itself by just backing up. Yes I do spray everything with some slickery stuff......NEVER have I even thought about sticking my hand in there ! Just shows " you can't fix stupid"....
I was on active duty stationed in VA and the military flew us to RI to clear the 1978 blizzard........ LOL I still remember that!
airshot
Speaking of snow, I was wondering....can the weight of a LOT of snow on my boat, that is sitting on a roller trailer punch the rollers thru the hull? Its a fiberglass 20ft boat with a 90hp on it as well. Its that white lump next to my garage!
If you're he hull and super structure are solid then no way would it cause an issue. However, if the wooden structure is rotten then the fiberglass could fail and the roller could damage the hull. Neighbors have an old boat in their junk pile and the rollers or what's left of them have broken thru the rotted hull. No idea how long it has sat there......at least 26 years that we have been nearby.
  • Like
Reactions: KJM
KJM
Everything is solid under the floor. I redid it all a few years ago. Oh well, spring will tell the tale. Kinda wouldn't mind a new boat anyway.......
Lou C
I think extra weight from a static load (boat sitting with snow on the cover) is way different than a dynamic load (boat bouncing down the road). You can add rollers to spread the load if you feel you must use a roller trailer. Here they are preferred over bunk trailers due to wide tidal swings and shallow neighborhood ramps.
tpenfield
Some quick math says I have about 4,000 lbs of snow (water) on my boat . . . figuring from the several storms I have the equivalent of 3" of water on the accumulated . . . might be a little less, but not much.
