HighTrim
- Jun 21, 2007
- 10,486
Re: So I now own a 1978 55hp Johnson outboard
When you say the seal kit came with a gasket that fits perfectly under the impeller housing, is it an o ring that you are speaking of? The impeller will ride on it. As far as the procedure to remove the driveshaft and prop shaft, it is fairly lengthy, and should be covered fairly in depth in your manual. You will need some specialty tools though, such as a good set of snap ring pliers, bearing puller etc...
