JASinIL2006
- Feb 10, 2012
- 5,738
OK, I finally got tired of my boat bogging down and backfiring under acceleration. (Diagnosed correctly on iboats as a carb issue, of course!) Got a recommendation from a friend of a boat shop he has used with success and I took in the boat. Got a call to pick it up with a nice, clean rebuillt carb.
When I pick the boat up, after I've paid my bill, in the process of getting the trailer connected, I'm in the boat and I notice that one of the screwed-in snaps (that receive a strap to hold down the sunpad that covers the engine compartment) was pulled out of its hole and is stuck in the other side of the strap, as if the sunpad was popped up without first unstrapping it. A bit annoying, but a pretty minor thing to fix.
I get the boat home and in prepping for an outing, I notice that the wingnut that screws down the engine cover and spark arrestor is missing, and has been replaced with a plain old hex nut and washer. Unfortunately, the hex nut seems to not be threaded the same as the stem that sticks out of the carburetor and the nut is stock on there pretty good. Using a wrench on it causes the stem to unscrew and I eventually get the parts separated and figure out why the nut is stuck on there.
Finally, in putting on muffs to warm the engine before heading to the ramp, I notice the prop has paint worn off the front edges of the blades and there are some small nicks and gouges in the leading edges. This is a fairly new prop, bought in late July, that I know did not have those marks before I brought it in. (I know because I nicked a wing dam on my last outing prior to taking the boat in for service. I had nicked the top of one blade, and I took pics to post on here to ask if that nick would cause problems. At that time, there was no other damage to the prop.)
None of these things is a huge issue by itself. I don't think the performance of the prop was affected (I used it today and it was fine.) The wing nut isn't a big deal and the sunpad snap wasn't much to fix. I know I'm a bit over protective of my boat since restoring it, but taken together, all these things make me wonder what sort of care my boat gets from them. The carb work was successful and I no longer have the problem for which I took it in, but I'm not sure if I should shrug it off, talk with the service manager, or just cut my losses and look for different shop the next time I need work done. Any thoughts?
Thanks,
Jim
Thanks,
Jim
