Baylinerchuck
- Jul 29, 2016
- 2,740
I too am very particular in my wiring of just about anything, mainly due to the training I received as an electrician working for a defense contractor that built communication shelters and other various mobile projects including Patriot missile components. I have rewired numerous trailers over the years with electric brakes and of course boat trailers. All the boat trailers I've done have had surge brakes so I usually use regular flat 4 trailer wire, which is normally 16 awg stranded copper. Tinning refers to lightly soldering the ends of the wire which I may do to a ground wire that I am crimping a ring terminal to attach to the frame. I like to lightly solder that ground wire in the ring terminal after I crimp it.....many opinions obviously on this, I'm just explaining what I do. I never use solderless crimp butt splices, but take the time to solder and heat shrink every connection between the wiring and the light. I also never rely solely on the chassis ground of a light fixture and will run a short ground wire from the light ground post connecting it to the main part of a boat trailers frame. Again, this is what I do, and opinions vary. I hate rework.....I really hate flashing lights as I drive down the road at night. For plugs and connectors, use a quality dielectric grease to seal out the weather and protect conductors. I really like in these posts the idea of liquid electrical tape. I will certainly be giving this a try as I've never really used it before. I always secure all wiring to the trailer to inhibit excessive movement. This not only protects your work, but makes everything professional grade. I like to go the extra mile, but unlike the MIL stuff I worked on, I don't have a tie wrap every 1.5 inches. The extra time spent making it right will pay off years and miles down the road.
