something new coming in electric OB
Status
Not open for further replies.
It makes for a simpler drive train.----No different than azimuthing drives on big ships.----Or the electric motors driving the wheels on those monster mining trucks.----Read an article on mining trucks that do not use any fuel or battery charging from the grid.----They generate power loaded on the way down the mountain.----More power than is needed to run the empty truck back up the mountain.
DeepCMark58A
Unfortunately no downhill charging on a boat motor.
saltchuckmatt
unless you are rich and have your own powersource at your own private dock, where are you going to charge these things? big marinas will not let you tie up their shore power for anything less than a fortune, and on any given summer day they are booked months sometimes years in advance. also, a massive drawback for batteries that few mention is that they dont get lighter as you go. charged or full, you are still carrying around dead weight. weight sensitive craft like boats/aircraft suffer the most. and no, there is not going to be some magic tech that comes out and makes batteries 2x as power dense. physics/thermodynamics has its limits. Just because Elon Musk says its true doesnt make it so.
Well, I hate to say it but they all thought the world was flat until one guy ....
dingbat
I know that, but if the power from diesels is better as stated why introduce electic. Maybe at beginning for the tourque but once going?
The short answer is steel on steel traction with huge weight to HP ratios.
Much easier to control traction (torque) and speed electronically than with a gear box
Reciprocating motors generate torque by rpm. To maintain a content torque, yet variable speed output, would require a sophisticated gear box of some shorts with its inherent loss of efficiency.
On the other hand, the speed and torque of an electric motor can be controlled electrically with great precision with little, if any loss of efficiency
saltchuckmatt
of course the issue is still heavy , inefficient batteries. dead in the water.
saltchuckmatt
Sorry that I'm adding to this never ending end, to this thread.
Watch this and I had a little trouble watching it because of the platform but Yamaha's new hydrogen powered outboard.
jlh3rd
Master Chief Petty Officer
Why then do diesel locomotives convert to electric? Honest question.
your looking at it wrong. The electric motor isn't the problem. As a matter of fact, the electric motor might even have a greater power to weight ratio over an internal combustion engine.
Regardless, the problem with an EV is the "gas" tank, the battery.
Actually, the diesel engine/kerosene combination IS the gas tank that supplies the power for the electric drive.
There isn't a battery big enough to drive that locomotive.
dingbat
Developed for the Gemera four-seater, this electric motor, dubbed the Quark, is a tiny powerhouse. In a package that weighs just 63 pounds, the Quark develops 335 hp and 443 lb-ft of torque. For scale, that's a 330-mL energy drink in the pictures seen throughout.
saltchuckmatt
Status
