Something to worry about?
TomB985
Hey everyone,
I have a 1-month-old Larson LX850 with the 4.3L TKS Merc with Alpha1 outdrive. Last night I was running around 4,000 RPMs for about 2 minutes before coming to a stop, and I left the engine running to allow things to cool down a bit. I noticed a noticeable amount of white steam coming out of the water near the outdrive under the swim platform, and this is something I've never seen before. Is this normal? I'm concerned water may be making it into a cylinder somehow.
I grew up with outboards, and this is my first experience with an I/O.
Thanks!
tractoman
Re: Something to worry about?
Probably fine, what were the temps of the air and water? Steam can happen.
TomB985
Air was around 70? and water between 80-85?. Relatively low humidity though, it did the same thing tonight under the same conditions...4,000 RPMs for a few minutes then to idle.
Brentathon
I see steam coming from many boats (non-outboards) transoms. I think it's quite common. I think it's usually easier to see it on another boat, than the one you're operating.
Not only is water vapor a primary product of combustion (other than CO2), boats mix water into the exhaust stream.
