Spark Plug Problem 2005 200hp DI
one9
Re: Spark Plug Problem 2005 200hp DI
Where would I find the kill circuit? Also My batteries are a little drained from trying to start it for the past few days. But there is still enough juice to start the engine. To be on the safe side I will go ahead and charge them tonight.
HighTrim
It will be the only black/yellow wire. Disconnect it and check for spark again. And dont overlook the kill lanyard, ensure that it is properly functioning.
one9
Is the black/yellow wire connected to the ignition switch?If so I pulled it and the engine wont turn over. The system check comes on but that is it.
one9
I finally figured it out. After testing everything that has to do with the ignition system it turned out to be a bad starter solenoid. Which is weird because I just replaced it a few months ago. Turns out the old one was still working so I made the fix without having to pay for anything extra!:D
Thanks a bunch guys for all of the help
HighTrim
Interesting, strange symptoms for s solenoid, but good job on the cheap fix, that is the main thing. Now go boating!
one9
I found out on the newer engines there is 2 other connections on the solenoid 4 in total. One of them goes to the SAC (start assist circuit) in the EMM and that was where the problem was the SAC wasnt getting any electricity.
HighTrim
hmm, good to know. Good job on the fix.
