spark plug routing on 3.0 merc
bob johnson
my gfs son replaced the distributor cap on his motor and took all the wires off and cant remember how they go back on
we have the firing order, and i assume they go 1 2 3 4 from front of the motor to the back for the cylinders #'s...but which boss is #1 on the distributor cap??
thanks
bob
Dryon
Re: spark plug routing on 3.0 merc
Here you go
  • Mercruiser-Tech Handbook-1997-Engine 3.0L Firing Order.pdf
bob johnson
thanks, how would you determine which spot on the dist cap is #1??? the one closest to the block????
seems to counter what this picture is saying......but i worry they just print stuff to be representative and not exact!!
this was from a diagram for a 3.0 merc....were they different over the years....this is an original motor in a 2008 bayliner
PS i got that diagram after I posted the question from this site....
I am trying to instruct my gfs son via phone today...i hope i dont have him hook it up wrong
http://www.perfprotech.com/store/articles/mercruiser-30L-wiring-diagram.aspx
thanks
bob
Don S
The picture in the wiring diagram has nothing to do with firing order or location.
  • 09-02.pdf
Ayuh,... It really don't matter which spot on the cap you start with #1, so long as the rotor is pointing to that terminal at TDC, #1...
