Lou C
- Nov 10, 2002
- 13,955
It's easy to just ohm out your plug wires, not more that 1k ohms per foot of length is a good guide, and check the cap & rotor carefully with a bright flashlight for carbon tracking. Another trick I saw on Uncle Tony's Garage you tube is look in the cap terminals when checking wires, if a wire was not pushed all the way in when the cap was replaced, then the arcing could ruin the terminal on the wire and the one in the cap.
