Spark Plugs
Bill kubiak
Re: Spark Plugs
thanks, are they centerfire plugs???
It has ngk plugs in it now
Bill kubiak
Re: Spark Plugs
The plugs that were in it are NGK BUHXU-1 are they the same as the Champion QL78YC?
Laddies
Banned
Re: Spark Plugs
Fristly no spark plug manufacture that I know of will recommend using a cross over chart, they always state in their catalogs use the recommendation index, that being said a L78YC cross to NGK BPR7HS in my book. Not the same plug
Bill kubiak
Re: Spark Plugs
Got the Seloc manual today and it said the NGK BP8H-N-10 was the correct plug as well as the champion
Plainsman
Re: Spark Plugs
I'd listen to Laddies, he knows what he his talking about. The NGK replaced the champion for my motor.
gss036
Re: Spark Plugs
Check your owners manual, it will tell you the plug number to use. Which, was probably what you took out. You want to be careful using a hotter plug on a 2 stroke engine as they are not nearly as forgiving as a 4 stroker. You get a hot plug and a lean carb and you will hole a piston.
mgnau1
Re: Spark Plugs
Help!
What is the recommended plug for a Mercuriser 5.7?
1997
My owners manual gives no info.
Mike
Re: Spark Plugs
Magnau1 -- post your question on the Mercruiser/I/O forum. You'll get quicker and more accurate response over there.
Re: Spark Plugs
Bill -- check the port side of your engine. There should be a label on the exhaust cover that tells you the plug number.
MARCnAZ
Re: Spark Plugs
I have a 96, 115. Calls for a NGK BP8H-N-10. The Champion cross referance is the QL78YC champion. I've run both. No noticible difference. There is also a splitfire and a couple others which cross ref, but haven't personally ran them.
