Spark Problem
wannagofishin
I've got an '82 40 HP Merc (2 cylinder) with no spark on the top. I thought it was the coil but I switched the wires from the switchbox and got fire.
So, my question is - can a switchbox go bad on one side only? Can the problem be further up the line to the stator?
Thanks for your time,
Dan
Texasmark
Re: Spark Problem
I'll bump this up for you so that Laddies, Silvertip, Clams Canino, or WillyBWright may catch it. They can probably answer your question.
Mark
wannagofishin
Re: Spark Problem
Thanks,
I was hoping someone with knowledge would be on here. Laddies was a great help on my old 25 Merc about two years ago. Wish I still had that engine!
Dan
The-Machinist
Re: Spark Problem
I had the exact same problem with a 402 merc a while back. While it was an expensive risk, I went ahead and replaced the switch box. It fixed every problem I was having.
ricksrster
Re: Spark Problem
Check the Trigger. Disconnect the Brown/white and the Brown/Yellow wires from the switch box. Test the resistance between them. You should have 750-1400 Ohms. If not you have a bad trigger. If you do get these readings then Check voltage going ti coils from the switch box. Each coil should have 180V+.
