spark test Q
avantifishski
trying do a spark test on my 88 90hp Johnson Which kind of tester should I purchase? inline?
boobie
Re: spark test Q
Get an open air gap tester and set it to 7/16". Stay away from the neon ones.
Will Bark
Re: spark test Q
Auto-Zone; ORillys or any auto parts store available to you. Good luck
jakedaawg
Re: spark test Q
Stevens instrument Company sells the ones reccomended by Evinrude. I believe its the S-94 or something. I would bet that you could buy one on this website and help support the forums.
Re: spark test Q
Staple a couple of pieces of wire on a piece of plywood.-------Set up a gap of 7/16" between the ends.-----Stick one end on the block with an aligator clap and the other end into a plug wire.
avantifishski
Re: spark test Q
ok got the open air gap tester from parts store..and hooked up to 1st plug wire and clipped to motor block,now what should be going on with the other 3 plug wires ? just hang there? (I have all 4 plugs taken out)
boobie
Re: spark test Q
Take some jumper wires and ground them out one at a time. Use the tester on one wire at a time.
avantifishski
Re: spark test Q
I grew up in FT. Myers but im not understanding what you mean by ground them out. shud I have all plugs pulled out?
boobie
Re: spark test Q
Pull out plugs. Disconnect the plug wires from them. Then ground out three plug wires and check the spark on the remaining one. Do the same to the remaining other three. OR !! Leave the plugs in and pull the wires off so motor doesn't start. Then check the spark on each wire one at a time.
