bear_69cuda
- Oct 10, 2008
- 2,109
Re: Speaker instalation. Is it safe?
You could carve out the appropriate amount of foam, and then the seat base becomes the sealed box. As oops said this will not be a big deal in regards to floatation... You could also place the sub under the starboard console, just above your feet, under instrument cluster..or on the port side as well, below glove box...
oops,
I think I may have given you some incorrect information. I will be keeping the factory seats on the factory box, just cutting a hole in the box to fit the subs. they are flush mount so I will not be losing any space or creating any type of tripping hazard.
My main concern was losing these boyancy floats that the box may create.
Bear, The subs need to be in a fully sealed box. (i may need to cut out all the foam to get the airspace needed for quality sound)...![]()
