Special zip-tie for shift cable bellows?
Bansheex13
I was told to use a special zip-tie available from any boat dealer but I can't remember what the zip tie was designed for,so I can ask for it at the dealer???
ziggy
Re: Special zip-tie for shift cable bellows?
i just used a regular zip tie. on top of the oem clamp as it turns out. i put them side by side, but it worked its way on top of the clamp. the zip lock tie is to the outside.... i put the zip tie there as i felt this was where i had my water intrusion at..... just trying to make sure i gave it the best chance for not reoccurring after shift cable and shift cable bellows replacement....
Reel Poor
I believe what you are referring to is a low profile cable tie. It conforms to a circle a lot better than the traditional ties do.
ziggy
do ya feel that is that necessary for a good seal rp?
Reel Poor
ziggy, I don't use the cable ties. I use the metal clamp that is provided with the replacement boots. While they can be a pain, they are pretty much permanent when installed/crimped correctly.
ziggy
that to me is the question. i did have trouble crimping that clamp. various different plieres to no avail. i just didn't feel i got it clamped on the best i could. hence why i put the zip tie on..... do you use a special tool? locate the clamp in a certain way to then crimp it down?
Reel Poor
ziggy it doesn't take much crimping. I use a pair of battery cable crimpers to crimp down on the clamp a little, works great.
Don S
The clamp that come with them is steel, in salt water, they don't last very long. The cable ties he is referring to are used for fuel lines by Mercury. Part number is 54-816311T
Bansheex13
Thanks again Don,that is what I was looking for.
