spec's for rochester 2 bl
MRS
I have a 2 bl carb. on 4.3 book as spec's for a 17083110 2 bl but my carb. is a 17085008 2 bl . I need to know float drop and float level cannot find spec's for the 17085008 any where. This is a factory carb that came with the boat 86 candia 4.3. Thanks for any replies...
wrench 3
The 17085008 doesn't show up until 1987 but the specks on it are exactly the same as the 17083110.
MRS
Thanks but if I set the drop 1-3/4 the back of the float will hit the bottom of the bowl so not sure if it is right could be thou, The level seems to be right 17/32. I am dipping in carb. cleaner now (Berrymans) nasty stuff but cleans it great Thanks for the reply.
wrench 3
As long as your measuring from the gasket surface on the air horn to the lowest point on the float, it should be fine. Every Rochester 2 barrel in the book has a 1-3/4" float drop.
MRS
Thanks all done went with 1-3/4 will try out tomorrow Thanks for the replies boat ran great for 5 yrs. then not so good carb. went south so hope this gets it back on track..:fish2: got fish to catch..... Thanks again....
