speed up
bsandy565656
Nissan 9.8 E F 2011 nsf9.8a3 four stroke. When I give it gas to take off it will stall out unless i pump it. Runs great other than that. Is there a ajustment to correct that? Any help thanks. bsandy
pvanv
Re: speed up
Probably running lean. Verify fuel line not leaking any air into it. Verify thermostat is not stuck open. Clean the carb... correctly, not just a spray-out. In the future, run the carb out at the end of each and every day to reduce the chances of varnishing, which leads to too-lean operation.
