Matt Mathis
- Jun 20, 2008
- 6
My speedometer dosn't work. No leaks in the pressure line. I checked from plastic insert to speedometer and the vent holes are open nothing blocking them. I removed the plastic insert in the bottom unit, used a piece of 10 GA wire to see if the hole was blocked on down, the wire went on down seemed to be open. Air should pass freely from plastic insert to vent hole? 90HP merc 82. HELP Matt.
