splash guards?
Almeja
Re: splash guards?
Are you talking about the ones for the transom well in an outboard ???
mtblackdog
Re: splash guards?
Yep I have a Lund Tyee II it has a real low transom well, thinking of whitecaps or wavewackers.
tashasdaddy
Re: splash guards?
do you have a splash well. if so, it should take care of the problem. if not get a good bilge pump, with as automatic float switch. if anchored stearn shouldn't be toward white caps, if running you should be running fast enough to keep them from breaking over the stean. yes, i have taken water over the stearn before, but it was my fault. ran out of gas had to change tanks with a trailing sea, my additional weight in the very stearn was just enough to take on about 5 gallons, from 2 waves.
roscoe
Re: splash guards?
I posted this a couple days ago, but the post has disapearred. !!
wavewackers.com
