Sport Jet 90 what plugs?
93baylinerjazz
The ones I have in the boat are NGK BUHW (surface gap). Are these correct?
Are the BUHW-2's better? I have also seen BUZHW.
I just pulled and cleaned the carbs and it still wont run for more than a second or two without holding open the throttle (even then it dies). Trying to replace the plugs now but want to make sure I'm putting the right thing in it.
Any guidance appreciated!
kend301
Re: Sport Jet 90 what plugs?
Champion L76V plugs are the factory plugs , Nothing works better
93baylinerjazz
Thank you! I am having trouble trying to find these locally, but am being refered to NGK 2622 (BUHW). Might be forced to give these a shot. At least they will be new :(
93baylinerjazz
nm... the newly built Autozone is the only place in town that has them :D
Thanks again!
kend301
No problem , when you need any advice , post up in here and you will get it
