- Jul 23, 2011
- 52,154
post a pic of the mating surfaces. That may be the source of your hydrolockingThe exhaust ports look rust free. The elbows have some buildup inside, but not messing with the mating surfaces.
Yep - that was my gaff. Bow was up. Cover failed. plug was in.If you store outside try to support & water proof the cover & jack up bow with plug out
Fuel pump should be off with the ignition off always.Lastly, after the engine is shut down, there is occasionally a sound of a small motor coming from the engine. I think It must be the fuel pump, but was unable to capture video or isolate sound. there is a hissing sound with it. I looked carefully for excess fuel. none. I will inspect the carb before restarting. my instinct was fuel pump - but please direct me. thanks.
Sounds like it was. You still shouldn't have enough fuel in the cylinders to geyser out of the cylinders, no matter how much you pump the throttle. Don't know how much of that was mixed with water versus straight gas.And, I don’t know that it’s Hydrolocking. That was an early guess.
Haha, I can write a book on it at this point. Most things need to be done quickly, however I would for sure pull your drive, likely you have water in your bellows and the accompanying mess of that. Also, if youre starter, alternator, trim pump were submerged, there's a good chance of failure. Although likely less with fresh water submersion.
Are procedures for post flood maintenance listed anywhere?
It didn’t geyser, But we’re mincing words.Sounds like it was. You still shouldn't have enough fuel in the cylinders to geyser out of the cylinders, no matter how much you pump the throttle. Don't know how much of that was mixed with water versus straight gas.
No, distinction is important. If the cylinders were filled with gas, that would indicate that your carb is overflowing and gas is causing the hydrolock.It didn’t geyser, But we’re mincing words.
I don’t believe there was water in the cylinders. Only the exterior of the plugs had rust.
Stuff a rag in them, tape, whatever. Wouldn't bother fogging. Take the lower off though, if the level was that high in the bilge your bellows are full of water, and you're looking at gimbal bearing/u-joint replacement at a minimum.No leak from manifold.
I didn’t fog.
My challenge is that I have to take it back to the yard while I order new gaskets for the manifolds and lower unit.
I don’t want to leave the ports exposed … plugs are still in. Manifolds are off. Lower unit still on. Should I fog the port holes and tape them up while I’m waiting?
Agreed. and I now think the gas IS causing a hydrolock. I described a small motor and hissing sound that ran after the engine stopped. I suspect this was the fuel pump, filling the cylinder again, and causing another hydrolock. After that, As I mentioned, the starter engaged, but didn't budge the shaft/cylinders. But after a few tries, it did fire right up. I didn't have to remove plugs to clear the cylinder that time.No, distinction is important. If the cylinders were filled with gas, that would indicate that your carb is overflowing and gas is causing the hydrolock.
relatively clean, 1 was dripping with fuel.What did your spark plugs look like?
Is there any other small motor/hissing sound that I could be mistaking for a fuel pump?First priority is to chase your fuel pump wiring. There should be no power to the pump unless one of two conditions exist:
1) The starter is cranking. During cranking the starter powers the Purple/Yellow wire which goes to the fuel pump.
2) The motor has built enough oil pressure to activate the oil pressure switch, which also powers same Purple/Yellow wire powering the pump.
Without either of those condition there should never be power to the fuel pump.
Probably. Hard to say without hearing it. You need to actually go to the engine compartment and listen to where it's coming fromIs there any other small motor/hissing sound that I could be mistaking for a fuel pump?
It could do either, but unless you're either cranking the engine or the ignition is in the on position, the switch has no power going to itWould a bad oil pressure switch close the circuit, or leave it open? I will test to see if it's stuck closed?
The oil pressure switch leads test open (no conductivity) with no power. I didn't test the sender.It could do either, but unless you're either cranking the engine or the ignition is in the on position, the switch has no power going to it
Thanks, Rick. that makes sense.What you might do is connect power to the purple/yellow, which will spin up the fuel pump, and then look in the carburetor without the engine running and see if there is any fuel leaking down the intake while it is just sitting there without the engine turning over.
