Re: Stabilized Binoculars
Image stabilization is a benefit for folks wearing eyewear when using the binoculars. Since most peoples visual deficit is different in each eye, this usually requires a different dioptric prescription value for each eye. Although nearly all binoculars feature a compensating adjustment, it becomes less effective with higher power magnification. In addition, the index of refraction (the speed which light passes through a lens material) is also different because most quality binocular lenses are made of glass (1.523 index) whereas most eyewear lenses are made of CR-39 plastic (1.49 index) or polycarbonate (1.5 index) Without getting too technical, image stabilization has a way of working all this out to maximize optical performance.<br /><br />Good binoculars without image stabilization can be had for much less. Check out what Carl Zeiss has to offer. These are very good German engineered products that afford premium optics.<br /><br />Kevin<br /><><
