Stacked 6 Carbs
flyingscott
More than likely it has a primer system on it. I am in WI it is 17 Deg outside and I have to take the dog out.
Yea and Im watching the flames pens game too. Yea our poodle/shi tzu mix lets himself out but he wont freeze to death at least. However, the coyotes getting him is a different story.
Yea i get that it doesn't have "choke." You just get a fuel spray. I thought that the carbs would have a cover though or something.
flyingscott
And why do I have three carbs but six cylinders?
That's just how it was designed. Your motor started out as a 2 cylinder in the 50s. then they put 2 more cylinders on then 2 more. So you basically have 3-2 cylinder motors in one package. If you look at any 2 cylinder motor they generally only have one carb for 2 cylinders. That's my theory.
GA_Boater
Why do I have two carbs and 4 cylinders?
It's way Merc/Mariner made them. It isn't a motorcycle, although Harleys have 1 carb and 2 cylinders - Just like our motors. LOL
GA_Boater
The one on the left attaches a photo and the one right embeds a photo. The right one is accessed after clicking on the Advanced Editor button between the Jack- O-Lantern and battery with the fish hook - Upper left corner of the Message screen.
So back to my original question, now that the pic is up. I'm not missing anything on the carbs. They are designed open like that. Some gas drips out after the motor is cut off. Just checking if this was normal.
I think it's a pretty fast motor for the boat. I had it WOT and was about as fast as I thought I should have been going that day. 16'6' 1984 Agressor Coochie Craft Fish/ski fiberglass.
GA_Boater
You mean the circled enricheners? The arrows are pointing to the float bowls on the side of the carbs.
GA_Boater
Late, but welcome aboard.
The enricheners are in lieu of chokes, so your motor doesn't have chokes. Nothing is missing. What horsepower? I used a 90 for the parts diagram, but the same carbs as a 115.
How bad is the drip and is it dripping with the motor down?
