This past Sunday, took the boat out. Launched drove around for about 30min. Various throttle postions idle, full, cruise speed. Anyway we pull into a cove and idle speed in for about 5 minutes. Then bam stall and all gauges dead. I turn off and on the ignition an couple times it starts. Only for a second, stalls again. We deside to anchor for a couple hours. My brother in law tows me out of the no wake zone. I try to start, success. I un hook from tow boat and throttle to the ramp about 6-8 minutes away at 4000-4200 rpm no problems, the only thing I notice is the dash volt gauge on the dash indicates slightly above 12 volts on the way back to the ramp. I tie up to the dock shut down, put the trailer in the water. Go to the boat to pull it around to trailer, it stalls twice I figure I will pull it around with dock lines. The wind is blowing pulling it around is not working I tell my son to try yo start. It fires I jump in and gas it to the trailer no problems.
Today I go to boat to poke around with the multi meter. I checked voltage at battery 12.65 volts, same voltage at red wire on key switch.
If I turn the switch to run position and check voltage at the purple wire there is a drop of about 0.1 volt, is this drop normal?
I am wondering what could cause this stalling no start everything dead situation????
I have been trying to find answers and found something that said maybe the slave soleniod I just dont see the conection to this part and stalling.
The only other thing I want to check but didn't is the voltage at the purple wire on the coil.
I did take the purple wires off the coil and clean them there wasnt any corrosion just seemed I could make them clean and shiney.
I assume i should not have much if any drops in voltage between any conections
Thanks in advance for all the help you provide.
Bill
Bill
