Re: stalling going in to forward gear
Bad lower shift cable, when was it replaced last?
propeller tied to lower unit preventing it from turning?should also stall in reverse.
The stalling if caused by activating the shift interlock switch is a sign of the cable binding, corrosion , etc.Remove the drive and the cable at the connector inside the boat and try moving with JUST 2 FINGERS, should be free and easy.
