standard horizon chartplotter 160 gps no sat reception
mikenjo
i have a standard horizon 160 gps with no sat reception antenna seems ok it worked normally when it was removed last year.was told there my be a master reset which may be causing the problem.does anyone have an idea what could cause the problem display works normally
dingbat
Re: standard horizon chartplotter 160 gps no sat reception
Remote antenna?
If so, you have a 66/33 chance of it working on a second installation. Especially if you used the antennas screw on mount. Wires come loose in the antenna.
Three moves. one worked, fixed one, scrapped one.
