The gauge at the far right is actually cut off from the video. It is the starboard voltmeter. Portside fuel gauge, which is the far left one has a bad sending unit, both tanks are completely full of fuel. So it is from left to right, fuel-fuel, oil pres.-oil pres., temp-temp, volt-volt. I haven't noticed the voltmeters reading anything but normal around 13 volts.
When I did the cap, rotor, plugs and wires on the starboard engine this spring, I noticed a wire that wasn't connected, so I referenced the port side engine to where it went and connected it the body of the distributor, wondering if it was disconnected for a reason.
Bondo - I will give the filter a try this weekend.
