Re: starcraft chieftain? what should I look for before I buy
You are pushy, aren't you?
Brad is going to look at her Saturday.
Ok, yah, sorry, missed that. My bad. K, Saturday afternoon then. Or sooner
OK, less of a punk more helpful....
I took a gander at the photobucket pics but I didn't see any of the bottom hull. I think that would really have my attention. Seeing as you are near the salty stuff I would be concerned with corrosion. I would crawl right up under that boat and and make a very careful inspection of everything. Look closely for pitting/damage. It kinda looks like you can see under that engine - take a close look under that, see what you can see. Again, damage/pitting.
From where I sit, I am seeing you'll need to do a complete and total rebuild, bow to stern. The whole thing. So, things like soft spots in the deck and transom - no matter, you'll have to rebuild those.
I'd also assume that driveline is worth parts or scrap only. Unless proven otherwise by a lengthy sea trial and a marine tech checking it out (not going to happen). Even then, I'd be thinking about how quickly I could remove it, sell it, and replace it with a late model Mercruiser 4.3, maybe even a 5.7.
The hull is what you are buying, take your time inspecting that.
The only other thing I'd be concerned about is if the trailer could get the big girl home
I hope that helps, cheers
