Starcraft Parts
tidechaser 1
Re: Starcraft Parts
i have been searching for dash switches for my 1997 starcraft starship. they are single pole double throw with center off. i have tried locally and can not find standard ones that have the center off.
thanks.
GA_Boater
Re: Starcraft Parts
Yes iT is
It may be new as in freshly made, from the ad.
Have made a copy of an old emblem
made of Plastic Polyurethane as seen in the photo
but it is a copy which may explain the T. For 40 clams he should at least put some black paint in the right places.
North Beach
Re: Starcraft Parts
It may be new as in freshly made, from the ad. but it is a copy which may explain the T. For 40 clams he should at least put some black paint in the right places.
Um sorry but they look a tad rough.....
Skagit Lakes
Re: Starcraft Parts
Hi all.
Anyone have the bow cap from a '67-ish Sea Scamp? Could use seat brackets, too, if anyone has some.
North Beach
Re: Starcraft Parts
VL, Here's the wheel.
And to update: I have two bow castings
One pair of lower rub rail endcaps in good shape slightly pitted and i mean slightly.
One original bow light from my 66 sunchief that was pitted real bad and I had it chromed. The pitting still shows but no one would notice on the front of the boat. Light doesn't have the insides but you can get thewm anywhere. I went with a light that holds a flag up front.
One Port side transom end cap for an I/O model-this means it's flat across he back and rounded up the side for the rubrail-will not work on outboard models.
Two windshield base end caps for any 60's model with the 4 peice windshield
Two transom end caps from an islander (75) model I/O SOLD!!!
One bow light with flag pole attachment one screw hole flange is cracked at the hole but this light would work just fine with insides
Oh yeah and a pair of transome handles from an 18'Holiday. I have a pair on mine-you aren't gonna lift the boat with em but i use them to tie off all kinds of stuff. They're in good condition.
Showing what has sold!
Also I'm wondering how many folks would be interested in me doing another run of the Starcraft Logos for the side of the boat. I hate dealing with these people but if 4 or 5 of you want them I'll suck it up and do another run???
GA_Boater
Re: Starcraft Parts
NB's logos look a 1000 times better than those eBay jobs. Are they powder coated aluminum or plastic?
North Beach
Re: Starcraft Parts
They're waterjetted out of aluminum stock and powdercoated. Very nice!
e150
Re: Starcraft Parts
I'm interested in a pair.
heyyou325
Re: Starcraft Parts
NB, it's not really the one I'm looking for, you're setting on it, but if you get enough other people together, I'll get one. Might take more than that to make it worth your while tho.
flyingd
Re: Starcraft Parts
I have a 69 18' 6" Cheiftain and need the front eye for the winch to connect to. Anyone have one for sale?
VanderLaan
Re: Starcraft Parts
What kinda' coin we talkin? I am taking the utility boat route with my Holiday, but those are pretty sweet.
Noie
Re: Starcraft Parts
Have a '77 Starcraft Tristar that I have restored. Still trying to find these light frames. Not sure if they are original equipment or aftermarket.
jbcurt00
Re: Starcraft Parts
You might post pix of the light frames. If you try the Fiberglassics.com library you might find a vintage hardware ad that shows them if you don't have pix or the originals to take pix of. If you have them & pix, post pix of the back if there are stamps or #'s someone might recognize the maker.
Noie
Re: Starcraft Parts
Yes clicked 'submit' then realized I forgot to add photos! Here they are.
jbcurt00
Re: Starcraft Parts
Well those are certainly going to need to be specific to your hulls contours....
Are you doing any other work to the Tristar? And rehab for function, or faithful restoration? If you're doing other work on the hull, you might look for any docking lights that would work & possibly slightly change the location or fit so that the replacements are functional. Just not 1977 SC Tristar accurate...
Either way, you might try some of the boat salvage yards listed here
jbcurt00
Re: Starcraft Parts
I don't know but these are close:
And in a fiberglass hull, could certainly be made to fit/work IMHO.
But ouch, $100+ for the light (guessing bulb) only on evil-bay. $450+ for a complete set of 2.
Iboats carries similar lights
As do multiple online retailers
Noie
Re: Starcraft Parts
Ouch is right! Looks like they would work though.
Restoration is close to faithful. Have enjoyed every minute of it.
Thanks your input and links.
