lakelover
- Mar 26, 2003
- 4,390
Re: Starmada Testing Laboratories
I put enough water in it to be higher than the seems where the sides meet the bottom, and marked suspect areas on the outside with a permanent marker. Before applying the Gluvit, I rebucked as many of the rivets as I knew about near the leaks as I could. I'm not 100% sure, but I think the seems are leaking. I went under the boat last week and smeared 5200 around all the rivets on the bottom. Once it's out of the water, I plan to run a small bead of 5200 along the seems. At any rate, I'm not gonna pull the deck! The leaks are manageable with the bilge pump, I get maybe 1/2-3/4 gph coming in. It's a personal insult though.
LL did you water test before the gluvit?
