Sat. 4/17 once during the Tourn I was fishing, I cranked my Yamaha 225 VMax, put it in gear and it died. Back to neutral cranked again and it did not happen again until time to go in and it did the same thing, only this time it would not start, click or do anything. Tried shifting back and forth checked the prop to make sure it was going in gear and then out, and after I was 15 minutes late for weigh in, it just cranked for no reason. At home, I took the neutral safety switch off behind the shifter and ohmed it and worked it several times. Took it to work and had a electrician check it. Again it's fine. Put it back in, and Sat. 4/24, late in the day again it just would not click, start or make a noise until I bumped the trim switch on the shifter and it cranked. It happened 1 more time the same way. I left it running after that so as not to be late. Any ideas about what this is all about?
