Starter doesn't stop when engine starts
ali'i
Re: Starter doesn't stop when engine starts
So are you going to sell it "As Is" ??
Whether the problem is fixed or not, it will be, "as is", with the problem clearly mentioned in the ad, plus a few other problems,
Crosbyman
well we are all back to square one ..
sale "as is" ===> means it is the next guy's problem.... end of issue
fix before sale===> replace the selenoid since disconnecting the battery is not likely to be a fix for a bad/stuck start key !!!
what is unclear is why a sticky relay contact in the selenoid would physically release itself when dropping the battery voltage (unless it locks up as describded above). It is a bit of a mystery.
In any event you need to do something .
