Hey guys,
I have a 2002 350Mag MPI engine.
Several months ago, I ended up with a loose clamp on my exhaust bellows that leaked seawater into the engine compartment. I believe the leaking water got the starter/solenoid wet and I am now experiencing a failing starter and solenoid (slave solenoid checks out ok, but master solenoid will just click -- try a few key turns and eventually it will connect and start).
Anyhow, I now need to remove the starter and solenoid to either replace or rebuild (at the very least inspect). With the design of the engine compartment in the boat, both units are virtually impossible to see as they are located on the underside of the engine -- just about in the worst place to access in my engine compartment. I've never removed a starter before so ended up calling the professionals (I'd take it on myself if I could at least see the thing, but blind is another story). He gave me a call today indicating he can get one of the bolts off, but can't turn the second due to the lack of room -- only way to repair is to haul the boat out (I don't have a trailer), take it to his shop, and lift the engine (the bill would not be pretty).
Can anyone think of an alternative here to yanking the engine? Is there some sort of flexible impact wrench or another tool out there that could apply the force needed (safely)?
