Starter for 2000 5.7L
jrisebo
Had a starter bolt shear off in the block. The block is set up for offset bolt spacing and straight across bolt spacing. Anyone have a part number for the straight across spacing?
2000 GS PWTR charcoal engine, VP outdrives.
alldodge
The across spacing is right at 3 inch
Staggered 3.25 inch
The 3 inch takes a different flywheel
Ayuh,..... You can't switch from one pattern starter, to the other,.....
The straight across pattern is for the 12" flywheel, 'n the staggered pattern is for the 14" flywheel,.....
Donald0039
Why not get the broken bolt out? Weld on a nut? Drill out with a LH drill bit and a screw extractor.
