Starter interrupted by choke
dave0120
When starting my force 125 when I push in the to activate the choke the choke engages and stops the engine from cranking. And if I push in on the key first the starter won’t function. Why is the choke interfering with the starter
dave0120
My force 125 has started a new issue. When starting if I push the key in to engage the electric choke the starter will not crank , and while I am cranking the engine the choke won’t engage.
GA_Boater
Cute new title, there are two issues. You duplicated the original post and you haven't read our rules.
Hookup a meter to the choke and see what the voltage does when the choke button is pressed.
dave0120
Voltage goes to 12 when the key is pushed. I’m sorry About the dbl post , when I 1st did it I got a message that there was a problem and it could not be posted.
dave0120
If I am cranking the engine and push the key in I get no voltage at all
dave0120
I took the choke off the ignition switch and put it on a separate switch and they both function properly. Wouldn’t that point toward a issue with the ignition switch?
GA_Boater
Did the motor start with the choke on a separate switch?
dave0120
I’ll check that switch wiring and to see if maybe it got jumbled up during replacement last year. Thanks for all your help.
