starter motor removal
Larry Thompson
How do I remove the starter from my Tigershark 1100. When trying to start, the starter just spins and doesn't engage.
GeeFrankk
Re: starter motor removal
First you buy the manual, then you ask the questions on what you don't understand...............!
CaptnKirk
Remove the bolts from the back of the starter and pull it straight out. If it doesnt come out easy, gently tap on it. Be careful not to break the end cap (the part that goes in the block), it can cost about $80, and the starter itself is usually around $200.
Captn---
