starter noises
richmatt
Just rebuilt my 3.8 V6 omc and tried to turn it over yesterday but the starter made a noise and didnt turn the motor. The noise is a continuous fairly loud "clicking" sound at about 5 clicks per second. The engine is a little tight from new bearing and pistons etc but I can turn it by hand (without tools - levers etc) using the crank pulley. <br />I have had two suggestions so far - its the starter clutch slipping or its the solenoid dropping in and out because its not getting enough power<br />I tend to favour the latter as I was trying to jump start it from my van using some long jump leads and even though I connected the jump leads to the engine and main starter terminal I suspect I was dropping too many volts across the connections. As it was the end of the day, didnt have croc clips to attach the voltmeter and couldnt reach the starter switch, I decided to pack up and wait till next weekend to have another go.<br /><br />What are your thoughts - battery/connections or starter drive clutch?
wallbanger2
Re: starter noises
Sounds like low voltage to me. Remove the battery from the van and place it next to the engine if your want to try jump starting it. Hope this helps.
