Capt dave 258
- Jul 14, 2021
- 86
Just picked up a 1984, Johnson 150hp that hasn't been running in 5+ years. Hooked up jumper cables from a battery directly to the starter and ground. Sprayed the bendix shaft with spray oil and silicone. The bendix initially engaged with the flywheel but would do so slowly, not enough to start the motor. Took the starter off and jumped it and it seemed to spin with high rpm's. Put it back on the motor and cannot get it to engage with the flywheel. It just spins freely at a high rpm rate. Thoughts on why it won't engage with the flywheel? Thanks as always!
