tnduc
- May 2, 2007
- 292
I had a "starter" problem today on my '91 Evinrude 90HP. Was starting up the motor cold, when on the third try I heard the starter spinning. I took the top off and saw that the start cog did not go all the way up to engage the flywheel. I manually moved it up, hit the switch and it spun the flywheel as normal. A couple of cold trys with my manually moving the cog up until the engine caught and ran. Once the motor was warm this problem did not repeat itself. Any ideas? The battery is new, tuneup recently done on the motor. Thanks.
