Starter problems, Please Help
skisupreme
I purchased a 92' Ski Supreme 21' with a 350 Magnum engine, inboard transmission, the boat is in excellent shape with 306 hrs. The boat starts and runs very well when it is cold, i will be out on the water for about 30 minutes driving the boat bring up the temp to about 180 degrees, come into the dock turn the engine off for about 5 minutes and then when i try to start the engine nothing, the engine will not turn over, dead, however, the volt meter shows 12 and all the gauges work, lights and horn work, just the engine will not turn over. Please help.
Haut Medoc
Re: Starter problems, Please Help
Welcome to iboats......:)
'Only when hot, huh?....
Is this a new occurance?.....
I would start by cleaning all of the electrical connections & see if that helps.....;)
